Configures the error handling process for CLI scripting on the switch.
abort-on-error | Configures Cli scripts to be aborted if a CLI error occurs. |
ignore-error | Configures the script to be executed when CLI errors occur. |
CLI: ignore-error Static profiles: abort-on-error Dynamic profiles: abort-on-error
You can change the error-handling options within the scripts.
configure cli mode scripting ignore-error
This command was first available in ExtremeXOS 11.6.
